Problem with reading and transferring over USB
- David
3 years 5 months ago #7550
by David
Problem with reading and transferring over USB was created by David
Hi !
I have the latest ISO apps on my iPhone, iPad, and PC.
I can send cbz and cbr files through iTunes on my PC, but some files give an error (see attachment).
Furthermore, I am unable to read my library over wifi (see attachment as well).
drive.google.com/file/d/1UxCihsLjAtCX9m8.../view?usp=share_link
drive.google.com/file/d/1nxGrJ67fyi2WWGK.../view?usp=share_link
Can you help me ?
Can you help me ?
3 years 5 months ago #7552
Replied by Luis Ángel on topic Problem with reading and transferring over USB
Send me over email one of those files? I suspect there is something about them. You can try using any app like winrar to extract the contents or analyze the files. Make sure it has a valid and supported format and the files are not corrupted.
The following user(s) said Thank You: David
- David
3 years 5 months ago - 3 years 5 months ago #7554
by David
Replied by David on topic Problem with reading and transferring over USB
Don't find your email so i have created a link :
(removed - thanks for the link)
Last edit: 3 years 5 months ago by Luis Ángel.
- David
3 years 5 months ago #7555
by David
One additional detail, I imported a file a while ago, I was able to read it, and I can still open it, but I am unable to read it over wifi (same error message: bad info from YacReaderLibrary).
3 years 5 months ago #7556
Ok, thanks.
Yeah, the file is ok. What platform are you running YACReaderLibrary on? Do you have any special characters in your disk path to the file?
- David
3 years 5 months ago #7557
by David
SYSTEM INFORMATION
Qt version: 6.3.1
Build ABI: x86_64-little_endian-llp64
build CPU architecture: x86_64
Kernel type: winnt
Kernel version: 10.0.22621
Product info: Windows 11 Version 2009
GRAPHIC INFORMATION
Screen pixel ratio: 1.5
OpenGL version: 4.6 desktop
Disk path :
"F:\Books\Monsieur Tortue (2021).cbr"
Qt version: 6.3.1
Kernel type: winnt
GRAPHIC INFORMATION
Disk path :
3 years 5 months ago #7558
Hmmm, I am running out of ideas. Are you able to browse you YACReaderLibrary library normally from the iOS app?
3 years 5 months ago #7559
Have you used the "Delete metadata from selected comics" functionality at some point with that file?
If you can, please, go to the folder where you library is, you should see a .yacreaderlibrary there, zip it and send it to me so I can check what's going on.
- David
3 years 5 months ago #7560
by David
Sorry, it's a 2 go file...
3 years 5 months ago #7561
