Help updating to 9.5.0 on Raspbian/Raspberry Pi
  • CuriousGamer
  • Junior Member
  • Junior Member
8 years 4 months ago #4057 by CuriousGamer
I tried to re-build/install following the instructions on this site but I don't think it worked properly or just gave me the same version I had.
Running YACReaderLibraryServer --version doesn't do much, just gives me a list of commands I can use and the iOS reader says it needs a higher server version.
8 years 4 months ago #4059 by Luis Ángel
Replied by Luis Ángel on topic Help updating to 9.5.0 on Raspbian/Raspberry Pi
Get the code from this link:
github.com/YACReader/yacreader.git
you have to use
git clone https://github.com/YACReader/yacreader.git
instead of using hg
The following user(s) said Thank You: CuriousGamer
8 years 4 months ago #4062 by Luis Ángel
or you can grab the code from this link: github.com/YACReader/yacreader/releases/tag/9.5.0
  • CuriousGamer
  • Junior Member
  • Junior Member
8 years 4 months ago #4064 by CuriousGamer
Replied by CuriousGamer on topic Help updating to 9.5.0 on Raspbian/Raspberry Pi
Installed but now I get the error "Could not connect to the server" on my iOS device.
8 years 4 months ago #4065 by Luis Ángel
How big is your library? The first run needs to update the library to the new 9.5 format, it can take a few minutes depending on how many comics do you have
  • CuriousGamer
  • Junior Member
  • Junior Member
8 years 4 months ago #4066 by CuriousGamer
It's a tad large, I'm running a full update now.
Will report back when it's done.
  • CuriousGamer
  • Junior Member
  • Junior Member
8 years 4 months ago - 8 years 4 months ago #4067 by CuriousGamer
Updated but I still can't access my library on my Pi.
If I scan the QR code on my
Windows PC (accessing the same library over the network) it works fine and shows up no problem but not to my Pi.
Has the default port been changed? I was using 8080 before.
Last edit: 8 years 4 months ago by CuriousGamer.
8 years 4 months ago #4068 by Luis Ángel
No, it hasn’t changed, if you tried to run 9.5 while 9.0 was running maybe the app jumped to another port. Try to find the file YACReaderLibrary.ini and set the port there.
There path to that file is here in the forum.
  • CuriousGamer
  • Junior Member
  • Junior Member
8 years 4 months ago #4069 by CuriousGamer
I tried to change the port but still nothing, I checked the log and it says "Unable to create local server"
8 years 4 months ago #4071 by Luis Ángel
hmmm, that means that other instance is running, check that the previous version is not running.
Did you install the new version using "make install"? If not do it, then restart you PI
