YACReader 3.5 for iOS
  • Luis Ángel
  • Administrator
  • Administrator
7 years 3 months ago #4660 by Luis Ángel
YACReader 3.5 for iOS was created by Luis Ángel
It is ready for testing: testflight.apple.com/join/5zhB7sRP
Changes:
- Double page mode, can be set in the bottom bar while reading. Options are: single page, double page, and double page auto, in auto mode the double is enabled when the device is in landscape mode.
- New fit settings, now there is an always fit option to force the content to fit in the screen, no matter the orientation or the content aspect ratio.
- Faster image loading.
- Better image loading and caching when reading remotely (from YACReaderLibrary).
- New UI to open next/previous comic while reading, when the cover or the last page are reached trying to go further will open a pop up showing the cover of the next comic (or the previous comic if we are going backwards), taping the cover will open the comic. (This only works in local mode yet)
New in build 3.5.0.1:
- 3 additional tap modes, Viewer -> Options -> Settings (Page turn settings)
New in build 3.5.0.2:
- Fix page turns triggered while zooming
- Add a new setting to disable page turn animation, Viewer -> Options -> Settings (Page turn settings)
7 years 3 months ago #4666 by ClarkandBruce
Replied by ClarkandBruce on topic YACReader 3.5 for iOS
Hey Luis, been testing and the double page on iPad Pro is amazing. Also, the new fit works great. No adjustments needed. Very good update. thanks again.
I am Kal-El, the Man of Steel
  • Luis Ángel
  • Administrator
  • Administrator
7 years 3 months ago #4667 by Luis Ángel
Replied by Luis Ángel on topic YACReader 3.5 for iOS
ClarkandBruce wrote: Hey Luis, been testing and the double page on iPad Pro is amazing. Also, the new fit works great. No adjustments needed. Very good update. thanks again.
Awesome, thank you very much for testing it and for the feedback, it is really appreciated.
7 years 2 months ago #4721 by jocala
Replied by jocala on topic YACReader 3.5 for iOS
I just joined via testflight, thanks!
7 years 2 months ago #4756 by Drybonz
Replied by Drybonz on topic YACReader 3.5 for iOS
Hi Luis... I have just been checking out the new ios beta... you are making great progress. It is looking nice.
Couple quick suggestions I notice:
The remove margins feature is great... but I think it should leave a bit more of the marging... the reason is that on scans that are not quite straight (some diagonal movement) the borders of the book can get clipped a little. If it is relaxed a bit, I think it will look better.
Also, for the yacreader library, it would be great to have a "minimize to tray" option. (I have suggested this one in the past, but a long time ago. Just thought it would be a nice addition). A standalone server window that could sit in the tray would work too, but probably more effort to make this, I'm sure... just something to keep the server open and get everything out of the taskbar.
A quick contrast and yellowing adjustment button while reading would be very nice if the reader is switching between old and new comics, so they can make a fast contrast boost and remove yellowing from old comics.
I can see your development on the app is picking up and it is looking nice. Thanks for the time you are spending on the app. Best of luck.
  • Luis Ángel
  • Administrator
  • Administrator
7 years 2 months ago #4757 by Luis Ángel
Thanks for the suggestions, minimize to system tray is almost done, it is not yet ready because some weird behaviour in macos....
The following user(s) said Thank You: Drybonz
7 years 2 months ago #4758 by Drybonz
Luis... is it possible to get rid of the dock bar at the bottom of the ipad completely while reading? I notice that it goes away sometimes, but comes back. It can be a distraction while reading... I'm hoping it's possible to remove it permanently while the reader is open.
Thanks for considering this suggestion.
  • Luis Ángel
  • Administrator
  • Administrator
7 years 2 months ago #4760 by Luis Ángel
It is possible and it should disappear automatically, this was fixed time ago, are you on iOS 13? I will double check what is going on.
7 years 2 months ago #4763 by Drybonz
I am on ios 13.1 beta 4 (I think it's the most recent). The bar does disappear, but keeps coming back.
  • Luis Ángel
  • Administrator
  • Administrator
7 years 2 months ago #4767 by Luis Ángel
When does it come back?
