Development Releases
  • Luis Ángel
  • Administrator
  • Administrator
9 years 6 months ago - 4 years 9 months ago #3062 by Luis Ángel
Development Releases was created by Luis Ángel
From now on the dev builds are going to be automatically uploaded to: github.com/YACReader/yacreader-dev-builds/releases
This will make much easier to test new features and fixes.
NOTE: Hopefully GitHub will be the definitive home for dev builds.
Last edit: 4 years 9 months ago by Luis Ángel.
The following user(s) said Thank You: Qulox, Drybonz, tarasis, maxwill
9 years 5 months ago #3096 by Drybonz
Replied by Drybonz on topic Development Releases
Hi... I noticed there was a new iOS version in test flight. Is there a new stable version of the Windows YACReader we can use with that?
  • Luis Ángel
  • Administrator
  • Administrator
9 years 5 months ago #3097 by Luis Ángel
Replied by Luis Ángel on topic Development Releases
The current release should work fine with it, and the latest developer version too, it will be released a little bit later than the iOS version.
9 years 5 months ago #3099 by skrimaging
Replied by skrimaging on topic Development Releases
I just saw the iOS version beta in Test Flight.. installed it and love the new reader UI..
Is there a new macOS beta available that reflects the changes from the development release (seems only Windows version available on the topic).
  • Luis Ángel
  • Administrator
  • Administrator
9 years 4 months ago #3104 by Luis Ángel
Not yet, but it is ready to be tested
The following user(s) said Thank You: skrimaging
9 years 4 months ago #3105 by Drybonz
Hi Luis... I'm glad to see you have some new betas, etc... I was afraid you had stopped working on YACReader. There were a couple feature requests I had made a very long time ago and I thought I would check to see if they could make it into a new version.
I would love to be able to minimize YACReader library to the system tray so that it can be tucked away when it is running as a server to the iOS app. A standalone server in the system tray would also be a really great solution.
I would really like to be able to change the location of the .yacreaderlibrary folder with the cover thumbnails in it. It is being created in my comics library folder, which I would prefer to keep clean of extra folders.
Thanks for considering.
9 years 4 months ago #3107 by skrimaging
Cool! can't wait to test out the Mac Beta!
9 years 4 months ago #3109 by selmf
Replied by selmf on topic Development Releases
Technically it's more an alpha/development release, but it should be quite usable.
The Mac version is mostly finished, Luis just needs to figure out a good way sign the app so you don't get the "YACReader not found" bug when running it.
Drybonz, would the headless server work for your usecase?
9 years 4 months ago - 9 years 4 months ago #3115 by Drybonz
selmf wrote: Drybonz, would the headless server work for your usecase?
Hi selmf... I'm not familiar with the headless server. Is it something you already have in development?
*edit* Ideally, something like the developer of Comic Glass has for his app would be really nice. Just a small thing that sits in the system tray and transmits to the iOS app. It's here if you want to take a look: comicglass.net/download/toolsdownload/
Last edit: 9 years 4 months ago by Drybonz.
9 years 4 months ago #3116 by selmf
The headless server is YACReaderLibrary minus the graphical user interface. Literally just a command line app that serves your comics and has some basic library creating/updating features. It's mostly used by people runnning a Raspberry Pi or something similar to serve their comics but it's also available for Windows and Mac. No tray icon though :D
